if i have a dvd rom and a dvd writer , can i put the dvd movie in the dvd rom and a blank dvd in the dvd writer and clone the movie without riping him? ( in assumption that there both 4.7 gig)
( if yes so tell me the name of the program)
dose the program do an image file and burn the image?
or it can do it directly dvdrom to dvdr?
Results 1 to 9 of 9
No such program exists. Use dvd decrypter to rip to the hd and then burn.
so is there a program that do the ripping alone without my intervention?
that does the image to the H.D and then burn him to the dvd r?(4.7 to 4.7)
i`ll need to do the ripping menualy every time ? -
If the original dvd is under 4.3gig and already has the copy protection ripped off it(like say a copy of a dvd you already backed up or home movie you put ona blank dvd) you can just use nero and use the copy disc function.
In the tools section there should be a list of dvdrip programs
<--------over there some place.
DvDshrink DOESNT make you rip it to the harddrive so Baldrick is abit wrong that there are no programs. But it takes alot longer to do it from the disk than from the HD.
And the chances of finding a commercial dvd that's under 4.3gig is slim, Only some of the earliest dvd's released are that small. -
So please help me find a good&easy guid ...i`v search the guide section and there is like a milion guides over ther .....
oo... and what do you mean by"DvDshrink DOESNT make you rip it to the harddrive " -
rip the movie to hd with dvd decrypter
burn the movie with dvd decrypter
some movie don't have encryption on them
thicker than water and obstacles
are two movie off the top of my head with none
and these movie are always less than 4.7 gig -
It seems that your not asking a question so much as excepting/waiting to hear the answer you want
Bottomline is that you can not really do on the fly copying of DVDs.
To answer you specific question (about single layer DVDs). Use DVD decrypter. YES you have to rip the image first. Then CHOOSE to burn it.
For DVD9 discs there are several choices (and guides) to the left. I mostly use IC and DVD Shrink (often process first with IFOEdit, but DVD shrink 2.3 seems to deselect material without errors). -
jack_ass ya
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 19:18 -
ripped DVD plays, but won't burn
By Yes, me in forum MacReplies: 7Last Post: 3rd Sep 2009, 04:58 -
A little help can't seem to burn this movie after ripped to HDD
By f-zer0 in forum Authoring (DVD)Replies: 4Last Post: 10th Apr 2008, 22:13 -
**Help! Need to burn a DVD and running out of time to do it!**
By catdrummond in forum Newbie / General discussionsReplies: 1Last Post: 19th Oct 2007, 08:53 -
By catdrummond in forum DVD RippingReplies: 1Last Post: 19th Oct 2007, 08:51
